K8N Neo2 Plt problem
Akuma
I just built the system in my sig. But when I power on everything turns on fine. BIOS starts to load and gets to the screen that just says "Platinum" in big letter and "Press tab for blah blah" but when I press delete to enter BIOS it just stays there are doesn't do anything. I also tried with 1 stick of RAM but it did the same thing.
Please help.
Thanks.
try getting into bios with only cpu, MB, ram, see if that works, disconnect everthing else, and clear the cmos
I figured out from another thread that setting the IDE jumpers to Cable Select fixes it.
You can lock this.
