I have searched through forms all over and have seen many post on memory and the K8N Neo2 Platinum. My knowledge of computers is real good except for memory and I don't know jack about the settings and need help. This has probably been answered but I have not been able to find it and apoligize in advance.
I have an K8N Neo2 Platinum
AMD64 3500+ (Zalman fan)
1gb Kingston Valueram KVR400AK2/1GR 1GB 400MHz DDR (PC3200) DIMM CL3 (Kit of
two matched 512MB modules - supports Dual Channel) I KNOW!!!
60gb Maxtor SATA on 1
200gb Maxtor SATA on 2
ATI 9800
PSU - Can't see all the voltage but it is a 500 wt with good ratings (already changed it out with a more powerful one!)
Latest bios and nforce drivers (matter of fact, every driver is the very latest)
PROBLEM: I have not been able to install Winxp. I get that it can't find files on the cd. About every one out of 5 succeeds and then it doesn't work well, very unstable. (Programs lock up, or install problems with software.) I ran tests on all the componets and everything passes (Used SisSoft Sandra). Have not tried Memtest. I have tried both WinXP Pro and Home numerous times. I have replaced the PSU with a beefed up one, replaced one of the drives, replaced the optical drives, tried one drive, tried one stick of ram, tried different channels on ide and sata. I started to believe that that it something on the mobo and requested an RMA. Now, after reading around I am starting to believe it is memory. I bought the Kingston Valueram KVR400AK2/1GR 1GB 400MHz DDR (PC3200) DIMM CL3 at Fry's one day while I was in a hurry. I know that this was a very poor choice now but I have limited funds to get new memory right now and of course you can't return it.
MY QUESTION: What do y'all suggest to set the memory to so I can make sure that it is good and get my system stable. Any suggestions on settings in bios or memory settings would be greatly appreciated. I see a lot of 2.3-3-3-5 (etc..) but do not understand what to set in the bios. THANKS again for any help.
I hope this is enough info to help, if not let me know what else I need to post.
Thanks a lot again
LoneStar
ATI 9800
Thanks a lot again
LoneStar
