K8N Neo2 Plat Memory Question
Sinster
I'm running 512 x 2 What is the best config for running in dual channel?
I also have another stick of 512 of the same ram what would be the best config (if any) to run 512 x 3?
Sinster said:
......I also have another stick of 512 of the same ram what would be the best config (if any) to run 512 x 3?
bump because i want to know this as well :)
I was thinking of adding another 1gb to this board, but I have heard that it causes problems. Not sure about your question though.
2x1024 is your best bet to stay with dual channel. I was in the same boat with 2 x 512 dual channel doesn't run with 3 or 4 sticks only 2. So i upgraded mine to 2gb with two corsairs 1024 3200 twinxctpro this is the only way to stay in dual channel mode for me. I have the same board
what memory timings and overclock can you get with that setup ?
what CPU also ?
Uhh,...that's incorrect sir,...it will run dual channel with 2 or 4 sticks...the problem lies with double sided memory,...it will default to ddr333 (pc2700) and only at 2t command rate. Now,...if you've got yourself a new venice or san diego core,....that was supposed to fix the problem because apparently,...the problems wasn't with the motherboard but,...the on-die memory controller of the newcastle and winchester cores.
If you're going to be playing BF 2 or anything else that NEEDS tons of RAM. Then I'd go w/ dimm 1 2 3 w/ all 3 sticks.. I have 1 comp that has 1 gig of memory.. and the other has 1.5 gigs.. the 1.5 gigs runs better on bf2 just because it has more ram.
The comp w/ 1 gig of ram has by far better gear inside but has a huge bottleneck.. i had to rma the other stick :(
If you want the best of both worlds go buy another stick of ram and fill up your dimm slots for ddr mode.
