I'm experiencing a strange problem where my Neo2 PE won't post when I have 2 DIMMs in DIMM slots 1+2. I think I have this narrowed down to a dual channel issue based on the following experiments:
1 Single stick in DIMM1 slot -> posts
2 Sticks in DIMM 1+2 (dual channel) -> no post
3 Sticks in DIMM 3+4 (dual channel) -> no post
4 Sticks in DIMM 1+3 (single channel) -> posts
I've had this happen to me on 2 Neo2 PE. My old MB wouldn't post after a bad bios update. It booted into Windows, then showed signs of slowing down, then hung, then wouldn't post. And on my new Neo2 PE that I bought as a replacement. I never thought about looking into an issue with Dual Channel till I saw the exact same symptoms of not posting. Sadly the old board has been sent back to MSI for repair, so I can run the same experiments on it.
What is wierd is my memory worked in dual channel mode with a gigabyte GA K8NSC 939. I also confirmed it wasn't an issue with my CPU since both my Opteron 148 and Amd64 3000+ were running fine on both the Neo2 PE and Gigabyte.
Anyone have an idea what this might be or how to get dual channel running again. It used to work till I updated the bios on my old motherboard.
I have a set of 512MB OCZ PC3200 Value VXs which used to work in the Neo2 PE in dual channel mode and which I used for the above experiments. I'll be picking up a new pair of Memory from Fry's tonight to see if I can narrow this down to the board or the memory.
SF
SF
