K8N Neo Platinum vcore question
Xilikon
[H]ard|DCer of the Year 2008
I use this motherboard on my current setup with the 2.1 bios. There is a list of vcore options in % (3.3%, 5%, 7% and 10% from memory).
If we use the normal logic, I assume the % was over the base core voltage, which is 1.55v for my Newcastle. If i run at 5%, I'm supposed to get 1.63v but cpu-z report closer to 1.75v. At 3.3%, math should be 1.60v but mine run at 1.68%.
So my question is : From which voltage the % is based off (12v, 3.3v or what) ?
I had the Neo2 Platinum, I don't know if you're talking Neo2 or Neo4, but I'll go on anyway.
Your logic is correct if the other vCore setting is set to Auto and the board is detecting correctly. It was possible on mine and presumably on yours to raise the vCore two different ways. I had a winchester core that had a stock vCore of 1.4. In one menu I could raise it to 1.5, and in the menu that you're using, I could add additional voltage by percentage.
Look carefully and make sure that the vCore selection with the numbers is either at Auto or at the stock voltage for your CPU.
I got the original Neo Platinum, socket 754. There is indeed 2 options and i will recheck agin to make sure i understand how it works since it doesn't make sense.
Ah, my fault for not remembering the 754 version. Yeah, the % boost is above and beyond what the number says in the other setting.
