k8n Neo 4 Platinum compatibility?
If you mean model #RS-450-ACLY the answer is: maybe. It is a 24 pin ATX 2.0 PSU, so its fine as far as that goes, problem is MSI actually deviated from the standard and requires a -5v power lead on pin #20 of 24 for the sound to work. This actually isn'tpart of the ATX 2.0 standard. Some of the newer neo4's don't need that anymore (or so i hear, not 100% sure). That particular cooler master makes no mention of a -5v rail. I would look at an OCZ powerstream or modstream as those are confirmed to work, a few other ones are too but i can't think of them at the moment.
