After going through Asus' tech pages and doing searches here I figured I would post my current situation and ask for any recommendations on trouble shooting my issue while I wait for Asus to get back to me.
The following is pretty long, the basic if you do not wish to read it is that my machine is not registering USB devices, my floppy drive and my sound has gone to hell after 36 hous of working perfect.
Until I hear from Asus or users here my plan is to reset my MB and reload windows if I can get the floppy to work.
On to the summary of my problem that I had posted for Asus (sorry it is so long but I had no idea to what level of user I would be writting to on the other end)
____________________________________________________________________________________
After 36 hours of running flawlessly my USB Mouse MX-510 stopped working. I plugged a new mouse in and it did not work either. I reloaded my USB drivers and it continued not to work. I used a PS2 adapter and the mouse (MS-510) worked fine. Due to this error, I decided to update my Bios from 1001 to 1003 using the in OS update utility.
I was able to flash the bios with no problem, reboot and redo the settings for my raid drives. This did not fix my problems either.
Soon after my audio became distorted in a game, I tested it against another game and had the same problem. The audio seemed to be very slow and have a delay, the actual tone was low (very deep deep voices). I reloaded my Ac'97 drivers from the Asus Website and this did not correct the problem. I removed all my audio devices and rebuilt them in the hardware manager without it fixing the problem either.
After working on both of these problems for quite some time and double checking my bios I decided I would rebuild the machine.
During the initial Win Xp installation I was unable to read from my drive A floppy for the nVidia Raid Controller drivers. I tested the floppy disk in another machine and it ran fine. I opened windows on the new machine (which was still working since I could not reinstall yet) and it was unable to read the disk or format a new one. I removed the drive from the new machine and placed it into my old machine and it worked fine. I put the hardware back into my new machine and it did not work at all. I checked the bios and it was turned on.
What I am experiencing with multiple on board hardware failures appears to be either a MB defect or problem with the Bios. I have built many machines before, some with Asus MBs and they always worked fine.
What I need to know is how to fix these problems or test the MB to prove it is faulty so I may get a new one.
Please let me know
AMD 3400+ (ClawHammer)
Asus K8N-E Delux
2x512 Corsair XMS Extreme Memory Speed Series
2xWestern Digital Raptor 36.7GB 10,000RPM SATA (Raid 0)
XFX GeForce 6800 GT
~No O/C... yet
Please let me know
Asus K8N-E Delux
XFX GeForce 6800 GT
~No O/C... yet
