K8N-E burning out southbridges, help!
xorvious
Ok, long story coming....
I have a customers computer that we built just over a year ago that has run reasonably fine for its whole life up until now, specs;
ASUS K8N-E Dlx
AMD 2800+
2x512 Corsair value 3200
GeForce 5700
2x western digital 80gig raid 1
Athena 450watt PSU
Belkin UPS
USB Oki printer & USB thumb drive
That is what we started with, just after a year now the board died, first the usb ports stopped seeing devices then later that day it shut down, now no post. On opening the system up I found that the southbridge would slowly heat up maybe 2 deg f every minute with just the PSU switched on and the SYSTEM OFF. On turning the system on it would not post but inside of 30 seconds the southbridge (passive stock cooling) had reached 155f and I shut it back down.
So I am thinking bad mobo so we advance RMA it from ASUS put the replacement in and send it home only to have it come back a week later with the same exact problem. Check PSU rails, right on for voltage, talked to ASUS and the first thing they thought is that they sent us back the same board, but impossible due to the advance replace, so they say "you are just lucky, got 2 boards with the same problem" and didnt call me back and screwed up the next RMA (story for a different thread) so I put another K8N-E in we had for another build and sent it home again.
Two days later SAME PROBLEM, burnt southbridge, one more ASUS pooch screw later we get ANOTHER board, on ASUS advice we replace the PSU also figure why not and replace the optical drives and the hard drives to test the next board.
Well guess where this is going? A week later here is the system back again, this time the customer shut it down as soon as the USB ports dropped out so I believe it still posts but the SB is heating up again with the system off so I am 90% sure its going to cook if I run it too long.
So after cooking 3 boards I am compleatly stumped, I really doubt the CPU or memory is burning up boards and I cant see windows xp eating boards so any ideas? If you have read this far I thank you, I am now going to go beat my head against ASUS tech support and see what happens.
What about the USB devices being used on the ports, maybe one or more is faulty in some way.
I have thought about that, but it seems too unlikely considering the USB devices still work and they seem to have no problems with other systems. Besides I cant see how a USB device could damage a southbridge? uuhhgg I wish this system would just go away...
The onboard sound runs through the southbridge on that board does it not, perhaps it’s a bad set of speakers?
