K8N-DL setup worth it?
Destro
I'm currently looking to assemble a workstation geared for heavy multi-tasking, 3D/CG
and rendering.
For $650 I can get an Asus K8N-DL, 2x 265 Opterons, 4x 512MB DDR400 ECC REG
What do you guys think? Also, will it handle Vista well?
It won't perform like a more expensive system of course, but that hardware for that price... yea that's not a bad deal I'd say. That setup would be fine with Vista, another 2 GB or memory might not hurt, but 2 GB is decent, and it will perform just fine, especially if you run lots of multi-threaded stuff (which it sounds like you do).
Glad to hear this. Are there any bugs with this board?
Like memory compatibility, bios version to avoid, etc?
I'm running the K8N-DL with the latest bios (1009), AMD 290's and 4 gigs of corsair XMS1024RE-3200 memory, 2 74 gig raptors in raid 0. It is OC'd to 2954 mhz (211 x 14) as of right now, but the CPU's are brand new. I think when they burn in a little longer I should be able to get 220 -223 mhz on the cpu buss.
I'm happy with it so far...I use it 8 - 10 hours a day doing 3D Architectural
design, rendering and photorealistic raytracing.
Thanks for sharing mld45. When you get around can you check your board's
revision?
I read up quite a bit over at 2cpu.com and find out Asus released two version
of the K8N-DL.
Apparently to run Opteron 285s (and 290s I can assume) you need the latest
revision of the board (1.5 I believe) and naturaly the latest BIOS.
However someone at 2cpu is running a pair of 285s on the older revision with
the 1008 bios.
Unfortunetly my board is the old revision.
Guys, I got a great offer on 4 sticks of 1GB DDR333MHz.
Should I go for it or keep the 512MB DDR400MHz stuff?
Essentialy I still get 4 sticks so I'll be able to run NUMA. So it boils to less
but faster versus more but faster. They cost roughly $30 more then deal on
400Hz 512MB sticks.
