K8n Boot Problems! Urgent!
Snatch22
Hello everyone, i'm having a bit of a problem with my MSI K8n Neo Platinum.
When i have just my normal dvd rom installed (pioneer.. something old anyway) I boot up just fine.
Originally, when i first got the board, i had an asus 52/32/52 (i think?) burner, and i would get crashes on winxp install.. until i removed the drive. I figured the drive was the issue. Anyway, i now have bought a BenQ 1620 dual layer dvd writer, and i'm having the same issues if i have it installed in any configuration (e.g. solo on master, with the poineer drive as master and as slave, anything you can think of pretty much) The system will post, get to right BEFORE winxp starts to load, and then a crash/restart loop starts. It all goes away once i have the dvd writer off of the ide bus. I've also tried it on ide2. Anyway, these are my specs, i hope someone can help me out...
MSI K8N Neo Platinum
1gb ocz pc 3200
athlon 64 3200+
radeon 9800 aiw
soundblaster audigy 2
2x seagate 120's in sata raid
If anything else is needed.. please please let me know, i cant seem to figure this one out.
