K7S5A HHD Problems...
Tim Wardlaw
I have just installed a 3rd hdd into my system. An 80gb Samsung (SPO802N).. Now i install the drive, and my system will only see it as a 32 gb drive... i have played with the settings in CMOS but nothing will allow it to go to the 80.. I checked ECS's website for an updated bios, but it mentions nothing of harddrive support.. Anyone have any suggestions? the other 2 drives are a west diggy 120gb and a max 80.
thanks for any info
Check the jumpers on the HDD. There is a jumper to limit the HDD to 32 Gig Only. Try fixing that and it might work fine after that..
Problem was jumpers, but not like above. I had my cd-rom set to master and my hdd set to slave on the ide chan 2... switched them around and now it works like a charm.. just formatting it now. thanks tho.
