K7N2 to a A7N8X
Dominat0r
Since these boards are both Nforce2 chipsets, you think I can get away with not have to reinstall my OS?
Any try this and have good results?
It's possible... I mean, I just moved from an ABIT KT7 (VIA KT133) to an MSI K7N2 Delta-L without completely reinstalling my OS... (though I did have to play around with the repair install and recovery console, and reinstall WinXP SP1 ;) ), and all's well.
Jumping from one nF2 board to another shouldn't give you any trouble... A while ago I took someoen from an A7N8X-Dlx to an 8RDA3+ w/ no issues.... didn't even have to reactivate.
Did you have to repair install? What steps would i need to take to ensure that everything goes well? Thanks for the reply...i really hate to have to reinstall everything cause it doesnt really change anything...
with XP, a repair install is all you ever need to fix even the worst software problems -- faulty hardware is a different story. A repair install is just like a fresh install driver wise cept you dont loose your data or settings.
kewl thanks for that site....
so if im not changin chipets just remove my video card drivers, revert my IDE drivers to Microsucks and remove my USB controller?
Sweet..i hope this works =)
you shouldn't have a problem, i did what the guide said on my brother's stuff cause i really didn't want to reformat him... it worked, but i reformatted him anyways
Well i kept getting error messages after a repair install, something about \windows\system32\config missing. I tried it about 3 times and just gave up. I reinstalled my Nforce drivers and it died then....I guess it just wasnt meant to be. Oh well....i guess i will have to start off fresh -=)
Thanks for the help everyone.....
