K7N2-L + SBLive + DirectX 9 problem
cHoCo
Hello Everyone,
I've got a problem I can't find information on anywhere on the web, so hopefully someone here can be of assistance to me.
Doing a 'dxdiag' after a fresh WinXP install shows that DirectX 8.1 is installed and my SB Live works fine with the HardWare Sound Acceleration Level at full. However, once I upgrade to DirectX 9.0b the 'dxdiag' sound report says that my Live is running 'emulated' and the DirectSound test fails saying that "playback will only be done from software buffers".
I'm running the latest driver versions of the SB Live, NForce drivers and ATI Cats (see my setup at the bottom of this post).
Anyone else have this problem, or can point me in the right direction?
Thanks for any replies :D
Setup:
MSI K7N2-L (latest NForce Drivers)
AMD Athlon XP 2100+ T-Bred B
512MB Kingston HyperX PC3200
ATI Radeon 9700 PRO (Cat 3.10 drivers)
SoundBlaster Live Value (Latest Live drivers)
Antec 430W TruePower PSU
WinXP SP1
Reinstall the SBLive! drivers and see if that fixes your problem.
Good Luck
OldMX
Originally posted by velocitypimp
you should always install direct x before installing your video card or sound card drivers
I always do it this way no problems what so ever. make sure you get the lastest updated software for your sound card from creative.
