K7N2 Delta not booting! Pweeeeze help!
tmarshall
MSI K7N2 Delta
Elixer 256mb PC2700
2500 Barton
I just got this mobo from eGay. It won't boot.
The fans spin, and I get one long beep.
Beeeep..............Beeeep.............Beeeep
I swapped video cards (PCI n AGP) still no worky :mad: :mad:
Find out who's bios you have got.
Google "bios beep codes".
Look up the code on the right page.
Could be memory or mobo.
Luck....... :D
One long beep= memory error.
Funny the memory works fine in the KT4 Ultra board
myself owning that same board have run into no-boot problems some times..
under the cpu socket, between the AGP slot, and power MOSFET small aluminum heatsinks are 2 jumpers (the left having 3 pins, top 2 shorted, the right having 2 pins shorted)..
unplug power, flush power supply (power supply button to ON position, and hit power switch a few times), then remove battery, put bios to reset position, and move the LEFT jumper under the MOSFET heatsinks down, to short the bottom 2 pins instead of the top.
eg:
Wait about 30 seconds. replace battery, put BIOS reset jumper back to normal position, plug power in and hit the power button (NOTE: do not replace the LEFT jumper by the AGP slot back yet..)...
it should in most cases boot, and run w/ 100FSB on any CPU... go into bios, set things how you want, save, and shutdown. Replace the LEFT jumper below the mosfet's back to shorting the top 2 pins.
eg:
this usually works most of the time for me. Unless its bad memory.
Also - - Have you tried using the D-Led thing that comes w/ MSI mobo's?
It's the Elixir RAM, apparently the MSI nForce2 boards hate it. I read it over on the www.nforcershq.com forums (which seem to be down right now), in the MSI section. Doesn't suprise me really, my old K7T Turbo2 hated Elixir PC133 SDRAM.. Try getting hold of some Nanya or Micron maybe even Kingston (if you've got the latest bios)
-Mavvy911
ive owned 3 different k7n2 delta boards and every one ive had a problem with. i think its just a shotty board in general.
ooo and the board comes with a little 4 LED thing that you plug in and it diagnoses startup problems.
have you tried the safe mode jumper? I think it J10 ... if I remember correctly ... I'll check when I get home tonight ...
not really sure what your problems are ... but I built 7 of these the past year ... and I use one personally ... (2500@3200) ... have no problems with them ...
