K7MK8 - manufacturer?
Focker
Friend is trying to figure out the manufacturer of one of his motherboards, all he can see on it apparently is K7MK8. 700Mhz athlon is in it. Anyone have any ideas?
is it running? if it is capture the bios string and it should tell you...or the guys at wimsbios could find the manufacturer
Buddy of mine has an Asus K7M. He's running a Slot-A Athlon 850MHz unit. Could be that.
Here's a website that has a review of the Asus K7M motherboard...there are a few pictures on it so you might be able to compare the boards:
ASUS K7M Review
...Dan
