- Mar 9, 2018
Was recommended to use K5pro paste for my VRAM and VRMs and viewed LinusTTs about it.
Anyone else use it?
How long does it lasts?
I repasted my i7-10750H/115w rtx2060 GL65 Leopard a few months ago with MX-4 on everything that had paste applied with the tube I had on hand but it seems the temps are coming up to TJmax for the CPU.
What would you use for the CPU and GPU, K5pro or other paste?
Might still use the MX-4 for the CPU and GPU, says it last 2-3 years. Seems the K5pro can be reused, just add to it and you can scrap off the fresh K5 and put it back in the tub.
Would prefer to get it from another market other than Amazon since they wrongly restricted my account and won't look into it.
thx, d.
Anyone else use it?
thx, d.
