Just wondering..
Northern
I'm wondering if this setup:
http://www.newegg.com/app/ViewProductDesc.asp?description=11-129-120&catalog=7&depa=1
Antec SoHo File Server Case with SL400w Power Supply will this be enough power supply specs here:
http://www.antec-inc.com/specs/sl400_spe.html
2xWD Raptors 36.7
http://www.newegg.com/app/ViewProdu...-144-200&catalog=14&manufactory=BROWSE&depa=1
Zalman 7000
http://www.newegg.com/app/ViewProdu...-118-109&catalog=62&manufactory=BROWSE&depa=1
Vantec Tornado 80mm
http://www.newegg.com/app/ViewProdu...-999-612&catalog=62&manufactory=BROWSE&depa=1
Mushkin lvl2 3500 1 gig ram
http://www.newegg.com/app/ViewProductDesc.asp?description=20-146-292&catalog=147&depa=1
Intel P4 3.0c
http://www.newegg.com/app/viewProductDesc.asp?description=19-116-156&depa=1
Abit IC7-Max3
http://www.newegg.com/app/ViewProdu...127-158&catalog=280&manufactory=BROWSE&depa=1
Will that overclock to 3.4-3.6 without overheating too much. Thanks for any info from those of you who are die[H]ard overclockers.
edit: Btw did my first purchase at newegg today and I put all the [H] people as my referer cause without soaking in all the information here don't think I could have gotten the nerve to build my own. Work on friends and families stuff just always was nervous about building my own. (hopefully it goes well):D
2nd edit: Added items written so you wouldnt have to click to know what it is. Also is the PSU good enough for that setup? Looks from my readings that the 12v rail might be alittle low at 18a? That correct?
A 3.0 going to 3.4 or 3.6 is doable. Excellent parts you selected. Good luck.
I agree. You got great ram, great mobo, and a good cpu. As always, overclocking varies. But I would feel pretty good about your chances of getting to 3.6gig stable. Probably even higher. With the tight timings of your ram, you will have a very fast pc.
