coffaholic
- Dec 24, 2011
Hi Everyone,
I just started folding again since the weather is cooling down and wanted to get my CPU and GPU going for your big push to pass EVGA.
I was looking for the easiest way to get things set up and I found mention of FAH GPU Tracker V2 so I downloaded it and set things up. Upon starting both clients, I noticed that my GPU was pegged at 99-100%, but my CPU wouldn't budge over 50%.
Here are my settings:
What it looks like when everything is running:
My SMP FAHlog:
I cant seem to figure out why it wont use 100% of my CPU. I can load it to 100% using prime or any other stress test.
I've tried updating FAH Clients from the FAH GPU Tracker's Setup menu, manually replacing the FAH.exe with the most recent one, changing the SMP CPU settings in configuration to "Use specified number of CPU cores" and set it to 8, and running just the SMP client without the GPU client in case they weren't playing nice together.
Any ideas would be appreciated.
Thanks.
My SMP FAHlog:
Code:
# Windows SMP Console Edition #################################################
Folding@Home Client Version 6.34
http://folding.stanford.edu
Launch directory: D:\apps\fahgputrackerv2\FAH GPU Tracker V2\SMP
Executable: D:\apps\fahgputrackerv2\FAH GPU Tracker V2\FAH.exe
Arguments: -oneunit -forceasm -smp -advmethods -verbosity 9
[23:24:22] - Ask before connecting: No
[23:24:22] - User name: coffaholic (Team 33)
[23:24:22] - User ID: 1482DDF2059B4D77
[23:24:22] - Machine ID: 2
[23:24:22]
[23:24:22] Work directory not found. Creating...
[23:24:22] Could not open work queue, generating new queue...
[23:24:22] - Preparing to get new work unit...
[23:24:22] - Autosending finished units... [September 19 23:24:22 UTC]
[23:24:22] Cleaning up work directory
[23:24:22] Trying to send all finished work units
[23:24:22] + No unsent completed units remaining.
[23:24:22] - Autosend completed
[23:24:22] + Attempting to get work packet
[23:24:22] Passkey found
[23:24:22] - Will indicate memory of 16288 MB
[23:24:22] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 10, Stepping: 7
[23:24:22] - Connecting to assignment server
[23:24:22] Connecting to http://assign.stanford.edu:8080/
[23:24:22] Posted data.
[23:24:22] Initial: 8F80; - Successful: assigned to (128.143.199.96).
[23:24:22] + News From Folding@Home: Welcome to Folding@Home
[23:24:22] Loaded queue successfully.
[23:24:22] Sent data
[23:24:22] Connecting to http://128.143.199.96:8080/
[23:24:23] Posted data.
[23:24:23] Initial: 0000; - Receiving payload (expected size: 1764192)
[23:24:27] - Downloaded at ~430 kB/s
[23:24:27] - Averaged speed for that direction ~430 kB/s
[23:24:27] + Received work.
[23:24:27] + Closed connections
[23:24:27]
[23:24:27] + Processing work unit
[23:24:27] Core required: FahCore_a3.exe
[23:24:27] Core found.
[23:24:27] Working on queue slot 01 [September 19 23:24:27 UTC]
[23:24:27] + Working ...
[23:24:27] - Calling '.\FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 8 -nocpulock -checkpoint 3 -forceasm -verbose -lifeline 4748 -version 634'
[23:24:28]
[23:24:28] *------------------------------*
[23:24:28] Folding@Home Gromacs SMP Core
[23:24:28] Version 2.27 (Dec. 15, 2010)
[23:24:28]
[23:24:28] Preparing to commence simulation
[23:24:28] - Assembly optimizations manually forced on.
[23:24:28] - Not checking prior termination.
[23:24:28] - Expanded 1763680 -> 1944296 (decompressed 110.2 percent)
[23:24:28] Called DecompressByteArray: compressed_data_size=1763680 data_size=1944296, decompressed_data_size=1944296 diff=0
[23:24:28] - Digital signature verified
[23:24:28]
[23:24:28] Project: 6947 (Run 0, Clone 193, Gen 46)
[23:24:28]
[23:24:28] Assembly optimizations on if available.
[23:24:28] Entering M.D.
[23:24:34] Mapping NT from 8 to 8
[23:24:34] Completed 0 out of 500000 steps (0%)
[23:30:36] Completed 5000 out of 500000 steps (1%)
[23:36:26] Completed 10000 out of 500000 steps (2%)
[23:41:50] Completed 15000 out of 500000 steps (3%)
[23:47:14] Completed 20000 out of 500000 steps (4%)
[23:52:43] Completed 25000 out of 500000 steps (5%)
[23:58:03] Completed 30000 out of 500000 steps (6%)
[00:03:38] Completed 35000 out of 500000 steps (7%)
[00:10:36] Completed 40000 out of 500000 steps (8%)
[00:16:05] Completed 45000 out of 500000 steps (9%)
[00:21:29] Completed 50000 out of 500000 steps (10%)
[00:26:42] Completed 55000 out of 500000 steps (11%)
Thanks.
