Just put a computer together for the second time ever, need some help.
PaddoK
Just put everything together. Intel Q6700, EVGA 8800 gts, gigabyte ga-p35-ds3r.
Just put everything together and starts up, the fans spin, but no image comes from the 8800 gts. Monitor remains black. Card is correctly in the slot and additional power thing is properly installed.
I feel pretty solid about everything, except the SATA cables, and the case cables. But everything is plugged in its named slot. What could be happening?
Also, the cpu fan is a little delayed, sounds like 3 or so clicks come from the CD drive area, then the fan starts.
Also, I couldnt find a place to plug in the following (case cables): "AC'97" "HD AUDIO" and "1394"
Am i just boned? should i take this to a computer repair place, or is there anything I can do?
ok, is the cmos jumper in the right position? if so, next step reseat the ram and gpu. power connector on gpu? what psu?
as for the cables, does your case have front audio ports and front firewire port(s)?
The HD Audio header is near the I/O ports. It's a green set of pins right behind the analog audio output block. HD Audio replaces AC'97 so you don't plug that in. The DS3R has no 1394 (Firewire), so you'd have to buy a card if you need that.
no its a brand new 8600GTS and I can't even get video out to the monitor
do you have any other PCI-E or PCI GPUs you could try?
does the board give the single beep of a post or not? (try switching the speaker plug around to verify polarity. It might make a difference, I dont remember)
Check to see that your 4pin ATX connector is plugged in.
Also, try "jump starting" the power supply separately. Paper clip between black and green wires will do it.
Do what JaYp146 said.
When jumpstarting the PSU, it should turn on and stay on once you jump those two pins (on the 24-pin main ATX connector) and the switch on the back is turned on with a power cable plugged in.
Also, try re-seating the CPU. If that doesn't work, pull out all ram and listen for error beeps. Make sure a system speaker is plugged in.
If that doesnt work, pull out the vidcard and listen for error beeps.
If that doesn't work, pull it all out of the case and reassemble on your desk with only the essentials. Place the mobo on its own cardboard box, plug in the cpu/hsf/psu/single stick of ram/vidcard/monitor/keyboard. Power the board using a screwdriver to jump the two power switch leads. Let us know the results.
