well, I got my tax return (nice one) so I ordered some WC stuff.
I got the RBX from danger den, along with their Maze 4 GPU block for my Radeon, and their Z-chip for the chipset.
Along with that I ordered 15 feet of 1/2" clearflex, their reservoir they sell on dangerden, 15 plastic hose-clamps, the pci-slot pump power thingy, and a danner mag3 from some aquarium supply store.
So, I still gotta go buy fans and a heatercore, make the mods to the heatercore and build an enclosure for the whole deal. Still, I'm feeling good about the purchase even though I got the RBX and not the WW. I think it should do just fine.
Any input? I plan to get the boneville heatercore that is big enough for 2 120mm fans, and build a lexan box that snugs up to the heatercore on all 4 sides, then cut 2 120mm holes in the top of the box where the fans will mount. The enclosure itself will act as a shroud.
yay.
This is not cheap! My buddy bought an EXOS and its working great, and only spent $250. Then again, I got a block for my GPU and chipset, and a way better cpu block and much better pump.. so I guess my system will be much better, though nearly $400. lol.
yay.
