- Feb 6, 2006
Like the title says, downloaded the UD client because my son has cancer and figured I'd help in that department. Only have my dual core computer to work with for now. Already joined Team {H}
marty9876 said:Great. Just so you know, not taking sides here, UD can only use one core of your CPU and not both w/o some fancy doings (fast user switching or something like that).
Most guys run 1x UD and 1x Stanford FAH in these cases, totally your call. Just wanted to point this out in case you wanted to run the system as much as possible.
I hope for the best for your son.
mwarps said:Welcome. Pull up a chair. Molest a moose.
ryan_975 said:I think I'll pass on the Moose Molestations. Thanks though
marty9876 said:just beat him with a stick then.
You can run 2x clients and not notice any slow down I bet. 95% chance of it.
How much RAM in the box?
mwarps said:I'd say a greater than 95% chance if you run 'em at 75% each core![]()
marty9876 said:that's 150% more than you then?
marty9876 said:Be a man, install the console client...![]()
Check you task manager, what's that other core doing right now anyways?
Wise decision. Welcome to the team. I am glad to hear that your son is doing well, perhaps you can add your experienceryan_975 said:I think I'll pass on the Moose Molestations. Thanks though
http://www.hardforum.com/showpost.php?p=1027699981&postcount=5ryan_975 said:The only question I have at the moment is how do you guys get the little stats thing at the bottom or your posts? It doesn't seem to be part of your sig since it's quoteable. And I'm sure you don't type it everytime.
ThanksKodiakStar said:http://www.hardforum.com/showpost.php?p=1027699981&postcount=5
Go here
Welcome to the team, and if you need anything Anderu is the UD "Gawd" here![]()
p[H]ant0m said:Normally you can count on about 3 to 6 hours after you finish your first WU. Sometime it can take a little longer.
