Just installed my 4850 card
Cally
I bought this several days ago at BB on their $150 sale. I installed it this morning and other than my error of removing nvidia ethernet drivers it all went pretty well. The card was running at 76c I installed rivatuner 2.11. I raised the fan speed to 37% and the temps dropped to 53c. I don't hear any increase in fan noise so I will leave it there, I like cooler.
The last time I had an ATI card I used a program that showed the temps in the quick launch area. I think it was the ATI Tools not sure though. I would like a visual on the temps just for the heck of it.
Look in the overdrive section of your catalyst control panel. It shows your GPU temperatures. I would also recommend checking out this walkthrough on how to setup user profiles to control your fan speeds within the control panel's overdrive section.
ATITool should still work, at least as far as temperature monitoring goes. Last time I checked none of the other features of the program such as overclocking or fan speed control worked with the latest cards yet.
I found out something very interesting today while playing my game. With the old Evga card I never had a problem. Today I kept getting a black screen and having to reboot. I could still hear the music but that was it. After 3 times of this I checked temps of the vid card. They were in mid 70's. I unchecked the Fan control on riva tuner and let the card do its own fans speeds. It is running 70c now and I haven't had a problem in the game for the last hour.
I am thinking that controlling the fan speed at 39% may not be a good thing for me?
I believe the fan is designed to spin faster when the card gets hotter. When you set it at 39% it stays at 39% no matter how hot the card gets. My suggestion is to set the fan higher is you want to maintain cooler idle temps. I have mine at around 45-49% (it gets really loud at 50%) and I haven't had any issues.
I agree. The fan will reach 40% - 50% when playing games and even higher when running certain benchmarks or Furmark. By locking the fan at someting like 37%, it will run cooler than at default speeds when idle, but it will overheat when running games. Just leave it alone and you'll have a rock solid videocard with very little noise.
That is what I ended up doing now. I bumped up my exhaust case fan a notch and am letting the 4850 do for itself. I think that is the best way for this card. I played my game for over an hour without any problems. It is getting to look better and better now.
i made the fan ramp speed ramp up with temp using rivatuner, works pretty good and is quiet when i want it.
http://forums.guru3d.com//showthread.php?t=272323 and
http://www.overclock.net/ati/380013-radeon-48xx-rivatuner-guide.html
will get you started, he uses the static speed but just select the auto one.
to edit the fan table:
"Now, Click on the power user tab and read any warnings you get, If you want to continue, ignore these. Now head down to the "Rivatuner/Fan" entry, expand it, and you will see an entry called "AutoFanSpeedControl", and in the editable box beside this, enter "3". This enables you to edit the fan speed table."
one last thing, the duty cycle on the fan table does not seem to correspond to fan speed % as per gpu-z so to get 40% speed it had to be 50 something, and at max temps the duty cycle is over 100 but working fine
