kcmastrpc
- May 26, 2011
See title.. It's been upgraded to 10gb of ram, and has a couple extra hard drives but the video card that came stock with it is garbage (I'll still use it though for a 3rd and 4th display).
I have a powercolor ax5770 1gb (it has a DVI, VGA, and HDMI port on it). I've been gallivanting around the hack forums and what they're saying is that I should be able to slap the card in and it'll run without any bios hacks (I'll be running ML so I imagine the drivers will be there).
Here's my question, will I get full QE/OGL support? I remember using this same card in a hackintosh dell inspiron 530 running 10.7.6 and I could never get the darn thing to recognize as a true 5770 (always popped up as a 5700 series).
I also plan on running two X25-E's in raid0 config for my OS drive - and I'm wondering if anyone has a recommendation on a 5.25 to 2.5 mounting tray for the optical bay that'll hold two drives.
Thanks!
Thanks!
