Hey all,
I received my Viewsonic VP912b monitor a couple of days ago and since then I have been trying to calibrate the monitor.
The black colors are not quite as black as it is when the monitor is turned off. In addition I can see some white traces near the side edges of the screen and at the bottom. It appears to me that the backlight is not even. Also if you notice the screen on a bright colored background it seems to tremble. I am using the DVI cable that came with the monitor to connect it to my 9800XT. Tried the d-sub but I got the same results. Also in order to have the monitor calibrated well enough I had to set Contrast & Brightness to almost 0. Actually i have contract 6 notches from 0 and brightness 3 notches from zero.
Do you guys think that uneven backlight and trembling picture are good reasons for RMA?
