Just got my system.. does this look correct? o.O
Jadestar
Okay. I got my rig put together the other day and just ran a few programs. It's a Q6600 at stock speeds on a P35C-DS3R motherboard with 4GB of DDR2 800 and a 8800GTX. When I ran 3DMark06 my score was 11033, which was low compared to other similar systems.. the graphics tests seemed to run okay, but when it got to the CPU tests the thing totally slugged.. like 0-2 FPS the entire time. This doesn't sound right.. or is it? I'm running Vista 64-bit with the latest Forceware drivers.
The other thing that somewhat concerns me is in CPU-Z... 1) What's up with that core speed? Shouldn't it be higher, along with the multiplier? 2) Um.. is it bad to have that ratio on my memory? I've heard that 1:1 is best, for some reason I thought I would achieve it with stock speeds on my memory and CPU..
Any insight is very much appreciated. =) Thanks!
Edit: I meant to circle the FSB:DRAM ratio on the last image. Too lazy to redo it. :p
I know my memory should be at 4-4-4-15, I just poured over the BIOS and I can't seem to figure out how to adjust that, either. =/
Edit: Nevermind, got that part figured out.
Edit #2: 3DMark06 score after adjusting the timings: 11032. =/
It may be the vista but I get over 11k with an overclocked e4300 and 8800 GTS... (win XP)
What is the memory rated at? 4-4-4-12 is what I would shoot for, 5-5-5-15 is the default standard DDR2 spec setting. It looks like the CPU is either clocking itself down in a power-saving mode or the multiplier isn't set correctly.
If the ram is DDR2-800, then leaving it at 400MHz isn't going to hurt anything. The memory ratio doesn't really affect performance enough that you should worry about running 1:1.
EDIt: For the record, I get 9950 in 3dmark06 with my 5600+ and moderately overclocked GTS320. At max CPU and GPU clocks I could probably hit 10500-10750.
Thanks. 4-4-4-15 is what the memory is rated at. I'm not sure why CPU-Z is telling me that about the processor, because POST and 3DMark06 both tell me that the CPU's speed is at 2.4, and the BIOS says I'm set to 9x266.
Enhance Intel Speedstep Technology (EIST).
FYI:
CPU Clock speed = (CPU Multiplier) x [Base FSB speed]
RAM speed = 2 x [Base FSB speed]
Effective FSB speed = 4 x [Base FSB speed]
EIST usually lowers the CPU multiplier when the system is not in use. Run super pi and then take a ss of CPUZ, while its still running.
Ah, yeah-- I actually discovered this EIST thing just a few minutes ago and disabled it. I also adjusted my power-saving settings in Vista, and updated the OS.
11,182 -- small boost. Does that seem about right for my specs, or are there other things I should look into? CPU-Z reports my clock speed as a static 2.4 GHz now.
I'm thinking about trying to overclock my CPU and/or video card modestly.. is this a good idea, given the B3 stepping and all? I don't know a whole lot about it, what's the simplest way to ensure a small, safe overclock? Do I need to adjust voltages, or can I let the BIOS handle it by keeping the settings on automatic? It recommends an 'auto' setting if you adjust the FSB, so I'm assuming this is fine? Will I need to tinker with my memory as well, and if so should I be pretty safe to do so?
Go visit the OC'ing forum and give it a go.
Oh, your sig is a few lines too long. ;)
