Just got my replacement mobo
fastcoke11
And it still doesn't work! However, it's encouraging for this reason. I set it up with just the processor and HSF setup (on a piece of cardboard)... and it said it had no memory. So I put in the memory, and it said system failed due to cpu overclocking. Anybody have any ideas about this one? Brand new board... how can it be an overclocking issue? I'll call Asus tonight about it... but I figured I'd ask you guys first... as you're not inept like some of those customer service people.
You know if you did put your specs in your sig, we would know where to start... ;) Tried resetting the BIOS? What's the exact error word for word and where does it show it?
Athlon64 FX-53
Asus sk8v motherboard
Corsair pc3200 RAM
No display to screen -- the POST voice thing says: "System failed due to CPU overclocking".
Sorry about that. I'll try resetting BIOS when I get home later. Thanks for the reply.
Reset with no result. Please don't tell me they sent me a bad board... I'll be pissed... I need this up and running by sunday.
Anyone...? Anyone...? Bueller...? Does anybody have any ideas here? I mean... otherwise I might as well return all my parts and buy a freakin dell... because after this much trouble it must be a sign.
SK8V so 940 pin. I had that error on one rev 2 A8V but I had video and could get into the BIOS to tweak (A8V's AI Overclocking feature stuff). Are your sticks registered sticks?
You know what? I don't think they are registered. That's definitely something I didn't want to even think about... I didn't want to have to RMA anything anymore. I'm also trying to get in touch with Asus, but they keep saying that all operators are busy at the moment... which makes me wonder how good their products are if they are too busy with people calling in. Thanks for the response... I'll try a stick of registered RAM that I have in another box.
If they aren't registered....BINGO. That mobo requires registered. Good call McCoy.
However... wouldn't it say the system failed due to memory failure? That's what I got when I didn't even put the RAM in. I'll try some registered RAM, but if that doesn't work... I'll be calling Asus back again today.
Edit - Tried registered RAM -- nothing. In fact, the other RAM I tried is specifically listed in the supported memory list in the motherboard's handbook. So that's not it. I'm calling Asus.
Regardless of the error message you are getting, registered is required, not optional. So even if this error isn't related, it still won't work until you have registered DIMMs in there.
Okay, well that's the second thing I need to get squared away. Asus tech support told me that the BIOS version (1001) does not support the chip I have, so I put in the other BIOS chip I just happened to have lying around (1002) which supports that chip. Still doesn't work. And with registered RAM and that BIOS, it still doesn't work. So now since everyone over at tech support is busy again... I need to wait for them to call me.
