Just got a 7200.11.. maximizing speed
noct3rn4l
As of right now I do not plan on running a RAID (2+ drives), just the one 500gb. Should i set bios to AHCI to get 3 gb/s ? Or can that speed be achieved just by leaving it on IDE? I've never done AHCI before so I dont know if that involves any extra/new steps to do a fresh install or its just a change-and-go thing. For the ds3r do i have to put the AHCI drivers on a floppy and then do a fresh install?
I also read it supports NCQ, is that the way to go to see best performance?
Also, would i realize the best performance using just a single 500gb partition?
My personal recommendation is choose a smaller partition size just for the OS and some of your most used applications, perhaps 50GB or so, maybe a little bit more, and then use the rest of the drive for "storage" or whatnot: games, more applications, movies, music, videos, etc.
I've never been a fan of big single drive single partition systems because of the fact that if - and note I said if a virus were to affect things, typically they know Windows machines use C: as the predominant system drive letter and therefore attack most anything on C:, especially the Windows folder. Splitting a drive into a system partition for the OS and the most commonly used applications while using other partitions or just the rest of the available drive space as a "storage" concept has shown - in my own experience, mind you - to be the better solution that one drive/one partition/everything is on this one space setup.
I'd say use the drive with a smaller 10-20% capacity system partition (between 50 and 100GB) and the rest as a big wide open space for the rest of whatever you plan to put on it.
As far as AHCI operation, as long as the drive is being recognized in SATA native ATA/IDE mode, it'll work just fine. NCQ has been shown in many benchmarks to not have any appreciable benefit on a single drive workstation class machine like a home user's desktop, even a "power user" like some of us are. It comes in handy when the machine is used in a more server like never sit still environment where the hard drive literally never gets a chance to take a break, not for a second - aka a server environment.
Go grab HDTach from www.simplisoftware.com or HDTune from www.hdtune.com and run some basic benchmarks on that drive. As long as it shows your burst speeds are well into the 200MB+ range, and sustained reads into the 80MB/s or higher range (probably average about 80-ish) then that drive is working fine.
I read something a while back that said "shortstroking" doesn't really work. Wish I could find it.
yea i removed the jumper... the drive is screamin fast; it installed windows in ~10 mins... i just wasnt sure about the IDE/AHCI/RAID setting in Bios as i read AHCI or Raid had to be enabled to benefit from NCQ which is supposedly the fastest way to run the drive..?
As I mentioned already, NCQ has been proven to not be "the cat's meow" as some might put it. In a stressful environment meaning a file server that is getting tons of requests for data at the same time (which is the situation most busy file servers are in 24/7), NCQ becomes valuable because it can take the requests for data coming in and serve them up in a way that's best and most efficient given the requests in the queue and where the heads on the hard drive happen to be at any given moment.
Normal desktop users, even POWER users like me and many others - perhaps you too - are never going to be hitting our hard drives with 200+ requests for data from 200+ different locations on the hard drive because 200+ different users need 200+ different pieces of data. It's just not going to happen.
Therefore, in a "workstation-like" environment aka your home or your single PC, etc, NCQ will actually prove to be a performance hit instead of a boost to some degree. It sounds like it should always be a good thing, but the testing and benchmarks don't show it.
If your drive is screamin' fast, then be happy that it's screamin' fast and get to using it. Don't get bogged down in worrying about the difference between loading a game in 1 second vs 1.25 or whatever... if the system works, fantastic, congrats. ATA/IDE mode just means the controller uses a different driver - it doesn't lessen the speed of the drive or the transfer rate because the data is still flowing over the SATA bus, and SATA II maxes out at about 300MB/s sooo...
That's why I suggested doing the simple benchmarks with HDTach and HDTune: if you see consistent burst speeds in excess of 200MB/s and sustained reads in excess of about 70-80MB/s consistently, that drive is working as it should be.
thanks for clarifying :)
Thats all i need to know, i wont waste my time with ncq <3 gracias
