Just finished TDX cooling
fentzinator
Finished TDX water cooling system and can't wait to overclock my FX55. Temps dropped from 44 idle to 36 degrees celcius. 51 underload to 43 degrees celcius. Using Sunon 120 fan but a little loud. Anyone using different fan on Thermochill HE 120.1 radiator that is quiet? Thanks
I use a panaflo medium speed 120mm fan it has decent static pressure and is fairly quiet they work well at lower voltages look for the ones made in japan.
vapb400 said:
throw a zalman fan mate in their, it makes an amazing difference
Thats the best idea i never had, i just got one of those Sunon 120mm fans, LOUD AS hell, I used ur idea and put my ol' fanmate from my old zalman fan, awwwessssomnesss, quieter than my gay 53CFM Antec fan, and still more cooling on my radiator. Fanmate = awsome
I was just wondering what makes a fan gay? :D
What makes a fan gay is when it has low flow, yo. And when the stinkin connectors keep fallin out the molex connector, screwin everything up. They should of made that exhaust fan a 3 pin.
