I started litecoin mining this evening and saw my top GPU was reaching 83c and my bottom one was reaching 77c.
So I decided to take the side cover off my case and see what that would do since I suspected I was not getting enough airflow through my case.
That only dropped the temp down about 3-4c in a few minutes, so I decided to point a 140mm fan towards the GPUs. That dropped the top one to 74c, and the lower one to 71c.
I then decided to mod the side of my case so I could mount the 140mm fan where I had been holding it.
After getting it all back together, I am now running 67c on both.
10c and 15c drop is pretty nice for the little amount of work I did.
