Just curious
Oldwolf
When you have 2 card in SLi configuration, which one of the 4 ports is used for the monitor output?
Or does it really matter? Just find one port and use it.
Or are the other 3 diabled in some way from ever being used if you're just going to be using 1 monitor???
And is it rotational, ie, if you rebuild your system, does it matter? Or will that port be recognized and the other 3 ports be disabled on boot?
On my system I can use either port on the primary card. None are enabled on the second card. The only way that you can run all four monitor ports is to disable SLi mode and just use them as a standard multiple monitor configuration setup.
