ShredderFan
- Jul 2, 2006
OK all, here's the setup..
Asus P5n32-SLI Delux Motherboard
PNY 1GB Memory DDR2 667
LGA 775 Socket T Intel Core 2 Duo 2.4 GHZ
Antec True Power Three 650 Watt Power Supply with 20pin+4 connector
ATI AIW X1900 Graphics Card
Xi-Fi Sound System Platinum
I tried unplugging the CPU Power, and the motherboard stayed on for more than 3 minutes, and didn't shut down, so I don't think it's a bad board. I unplugged one of the memory sticks, but I don't think it's that either, because when I had both in, and was able to access the settings for a few minutes, it registered the memory as being 2,048MB's with 2,047 free.
I unplugged the Hard Drive, DVD.....Not it. It goes to 'hard disk not found' error and then still shuts down after 30 minutes. When I unplug the Power Fan, it gives me a 'warning, voltage, hardware, or thermal problem, please check setup....'
So I'm thinking I applied the thermal paste wrong. I applied it according to the directions on the arctic silver website, and applied a small vertical line down the center of the CPU, where as last time I was told to only apply a small dot of the stuff the size of a rice grain. Could that be the problem?
When I have my old hard drive in, it also got as foar as the Windows xP logon screen, and then shut down after thirty seconds, so I'm thinking this could be the problem. I'm using the Stock Intel Heatsink fan too.
