Just built my first Ryzen (2700X) system - CPU temp question
Kelvarr
Per the subject, I just finished building my first ever Ryzen system. I threw a Corsair H100 (original) on it, because I had one laying around.
I wasn't too sure on how tight the bracket should go (I was using a screwdriver to turn it...it didn't bottom out - not sure if it should be or not).
Got Windows on it, and the "Ryzen Master"software...here is a graph of my CPU temps...is this normal? The peaks are ~43°C, and the flats are ~22°C. I haven't done anything strenuous on it yet...was just trying to figure out if I have normal temps first or not.
I don't have any system instability so far, just running Windows and browsing the web.
mda
That's very good for a 2700X.
Crank up PBO and the RAM and you're golden.
Reactions: Auer
