Just bought a used AW9D-Max...
UncleDavid218
The board is in perfect condition and has all retail accessories. Needless to say, I'm happy with my $130 purchase! However, there seems to be some thermal compound in the CPU socket. I PM'd the seller (not from this forum) and he said it was non-conductive (Ceramique I assume) and that he'd been running it for 5 months like that. I tried to use a safety pin to get some of it out but that was pretty much useless. Should I try and run with the compound in there? It's a very very small amount.
If it works then I wouldn't worry about it, maybe just dab the pins on the socket with some nail varnish remover (on an ear bud) to make sure the tops of the pins are clean.
Then don't worry about it.
