are you talking to me dejawiz? if so, my cpu is not a 2600 "k" it's non k, 2600. if I had the k version I wouldn't have upgraded it.
thanks. i am getting it on Monday. i am happy.
Mine is at 4.5Ghz air cooled. I use a hyper 212 evo and at full load it maxes out at 80C, typical usage it is in the 50s or 60s
So many choices to pick from. My recent buy at Amazon the Intel 4770K and H60 cooler fit the best outcome. Now need to buy the best OC motherboard, Asus Z87 TUF, Hero or Sabertooth will be my choice when I can afford it, hoping on a nice Christmas gift. Motherboard?
My plan is to get it to 4.5Ghz at 70 deg C and 90 deg C when gaming.
I call you lucky. Mine can hit 4.5 but needs 1.325v to do it. I settled for 4.2 at 1.21 because I don't believe in going over 1.3 in voltage. Even at 4.2, it gets to 100C with Intel burn; Idles at 39-40C; And I'm under a custom water loop with one of the best CPU water blocks on the market and a 360MM thick radiator.
I have a sense that the way our chips are connected to the headspreader on top (it's glue, dude) can actually be affected in a negative way by throttling and 90C is getting close.
is there a Haswell overclocking guide somewhere?
