I'm ready to upgrade my gaming machine from a AMD 2600+ XP mobile @ 2.4ghz. I will use the machine for gaming (specifically Supreme Commander). My budget is flexible as long as I'm not wasting money. I have done a lot of reading and I now feel educated enough to hear what you guys think.
Video card
My last two cards were ATI, but their drivers now use .NET which really pisses me off. A lot. I would not mind at all going with nVidia. I am willing to spend a good amount here, something around $450. Would it make sense to do SLI with two ~$250 cards? Going with one card, it seems like the nVidia GeForce 8800GTS ($460) is just below the best (8800GTX is $650). Not sure what the equivalent ATI card is. Would the 8800GTS be a mistake? Is the Radeon X1950 XTX ($420) good enough I should save my money? Is SLI with lesser cards better?
The game I'm targetting is Supreme Commander, so I need multiple monitors. Most (if not all) good cards have this. It may be worth noting that the resolutions of the two monitors I want to push are 1280x720 (primary) and 1280x1024 (secondary). So, pretty low resolution. I have read that SLI may not work well with two displays.
Processor
AMD has always been the cheaper and better (or atleast just as good) choice. Now it seems the prices are roughly equal. I am not against going Intel, though all my reading has been aimed at AMD so far. That said, socket AM2 is the newest and it seems like the AMD Athlon X2 5000+ ($328) is just below the best (5200+ is $412). Can I get the same or better Intel processor for the same price?
Ram
I found Mushkin 2x1gb DDR2 800 5-5-5-12 for $270. Sounds good as long as the motherboard can reach 2.1 volts or so.
Motherboard
Of course the processor determines an AMD or Intel motherboard. For now let's assume AMD. The nVidia nForce 500 northbridge seems impressive enough. The Asus M2N32-SLI Deluxe is $190, but seems a little like overkill. I don't need wifi, firewire, gigabyte lan, onboard sound, or raid. I don't need SLI if I decide to go with one video card. The Asus M2N-E seems better but can only set the ram voltage to 1.95, so thats out. I just need a basic, stable motherboard to play games on!
PSU
I'll need a new PSU for this box since I'm using my old one elsewhere. I don't believe in spending big bucks on a PSU. In the past I have always bought $30 Rosewill 350W PSUs and have only had one die on me. Is 350W enough or do I need to go bigger?
HDD
I'm looking at a 74gb Raptor ($152) or a 150gb Raptor ($223). However, I may drop this idea for a good performing 7200rpm drive to cut costs.
Case
This is the only piece I have already ordered. I got an Antec P180 from Frys for $70 (after rebate).
So in all I am guessing I need to spend about $800 on the system plus about $450 on the video card. If your budget was around $1250 (lets say $1400 absolute max), what video card, processor, ram, and motherboard would you buy?
Video card
Processor
Ram
Motherboard
PSU
HDD
Case
