just amazing i think
DirtyApe
i just built a new system using a 2.6C, the ASUS P4C800-E Deluxe 1GB Corsair XMS Pro, SP-94, the rest is inmy sig...i was very surprised at how easy it was to OC the CPU from 2.6Ghz to 3.2Ghz :D and on top of that my 9800 pro came with its own OC'ing software so that really helped to top things off with this sytem.
excellent! now run prime95 for a few hours to make sure your overclock is stable.
on a 2.6C you could get 3.3 - try bumping your voltage, which you didn't mention. nor did you mention what speeds/settings you run your RAM at.
ah yes sorry about that. i just poseted this and im at work right now and i dont remember what the voltage is but i thinks it is at 1.65 but i could be wrong. and the RAM is at 1:1 250Mhz :D and the idel temps are around 31C-32C and the load temps are 38C-40C mostly due to my warm room cuz i hate the cold..bbbbrrrrrr. anywho i am really enjoying the crap outta this system cuz my last system was an AMD system and this one is MUCH faster than it. the AMD was a Barton 2500+ OC'ed to 2.1Ghz w/ 512mb Corsair PC3200@200Mhz and my video card wasnt great being a geforce4 ti4200. that was fast but my intel system is much MUCH faster. everything loads much faster and games run smoother mostly cuz of the 9800 pro. and i was using the SLK-800U HS and a smartfan 2 fan plus the case had like 8 fans on it. :Dloud as hell but it was cool :D. kinda funny cuz this intel system runs much cooler by about 10C and both systems had ASUS boards too. sorry about the missing info man :D
could be your ram.
set your DDR voltage to 2.8, set the timings to 2.5-4-4-7 to rule out the RAM. you can tighten the timings down later - but keep the voltage.
corsair likes 2.8V - that's from corsair forums, posted as an answer by one of the corsair moderators.
