AgentxofxChaos
Agent of [H] Chaos
- Dec 16, 2002
I recently bought an old, used motherboard w/ CPU (FIC VA-503+) for an "upgrade" for some friends of the family. Anyway, I'm going to install this weekend once i get a hold of their old system. However I was going over/verifying the jumper settings (CLK, Freq,Sdram, and voltage) for the motherboard in combination with a K6-2 400 and noticed a weird arrangement of the jumpers for the voltage. Anyway the voltage is supposed to be 2.2V and the jumpers look as follows, :::: with the 2.2V setting being ::l: where the l is obviously the jumper. Hopefully that picture makes some kind of sense. Anyway that is the configuration to an extent. The only strange thing though is that there are two other jumpers in the row of points, the thing is though they are only touching one point each with the other half just hanging off the board, kind as if there were some spare jumpers and the person just threw them on there but made sure that they did bridge to points. Kind of like ;:l; where the bottom of the ; is the one point that the jumper is touching and below that the second half of the jumper isn't touching anything. So my question is, does this really make a difference, are the extra jumpers really serving any purpose or are they as i described, just spares that were thrown on there and since they aren't bridging the points, they aren't doing anything? Sounds like a stupid question, but I was just curious since I found it odd (never seen it before), personally if they don't serve any purpose at all, I would just rather take them off. I just want to verify that they don't serve any purpose before I start taking off the jumpers for the voltage, especially with an older CPU and MBD. Well thanks in advance.
