jump drive problems.. need help
rockdragon
so i went around transferring files throughout my work the other day. i exported files such as bookmarks, docs, and email files out of outlook.
as i went to import the email files back into the new outlook. it gave me and error saying that the files were corrupt. so i ran this thing called scanpst.exe. i ran it n it came up with errors and i tried to fix them. well that froze. so i ended the task... bad idea...
after that my jump drive became corrupt. i couldnt copy any files off it or open anything. so i ran a check disk on it. that seemed to fix it temporarily.
well the next day i put it in my computer and it wont work. the 'working' light is constantly on and i cant access it at all. it shows up in my computer, but has the default name 'removable disk.' when i try to open it it says 'please insert a disk into drive e:' even though its still in.
please help... i cant do anything with my drive anymore.
what about a format, will it let you do that? I assume that data still exists elsewhere.
See if you can use a drive recovery/partition recovery tool from the OS. If this won't work, see if a DOS based utility will see it and format it or recover the partition.
