I'm trying to setup simple jumbo frames on my home network. There will be one printer that is 100mbps, and a few wireless clients. Otherwise, all desktops support jumbo frames, and it is working well between two Realtek adapters.
The problem is with an Intel Pro/1000 MT adapter. I set it to 9014bytes (Alteon). Frames up to somewhere around 8000bytes work just fine. But if I try 9000 bytes, it knocks the NIC offline. It comes back on its own after a few minutes, and works fine as long as no 8000+ byte packets occur again.
With all adapters, if I exceed the mtu and specify -f, it shows that packet needs to be fragmented as it should. The Intel does not go down. This is good and normal.
If I don't specify -f, the Realteks will still respond to ICMP properly, obviously fragmenting automatically as it should. But it takes the Intel one offline for a few minutes.
What is happening?!
What is happening?!
