In a diversion of a thread on "Load Balancing" here:
http://www.hardforum.com/showthread.php?t=1082381
longblock454 made certain claims;
The discussion is fine, IMO, but shouldn't be in that thread. So here it is.
longblock454, in face of measurements to the contrary, how do you defend your claims? In which cases will it be important to have jumbo frame support in order to have good performance?
And then, how does a typical (home/mixed) network go about ensuring that jumbo frames support is available and viable? How do you mix non-jumbo capable routers with jumbo capable gear?
If you would like to rephrase your claims, please do so.
Let's have it out and get it straight. Maybe we'll learn something new.
longblock454 said:While on the gigabit topic, don't forget about the advantages of jumbo frames.
Gigabit with standard frames of 1500 will only net you about 350Gbps, give or take in most common situations.
Gigabit with jumbo frames can usually saturate the connection!
