Try a direct wire first before you try a new switch.
Switch support can be confusing, with different revisions in the same model supporting and not supporting jumbo frames. Which switch and revision are you trying?
Do you know anything about the DGS-1024D and which revisions work with jumbo frames and don't? I figure they'll just blow me off.You need to contact tech support first to establish an issue. Approach them politely of course, and basically saying "It fails when 9K jumbo frames are enabled; it was advertised as supporting 9K jumbo frames, and I bought it for that, etc., and here's what I did to establish that it's the switch's fault, i.e., it's not a configuration issue on my part. How can I get it fixed?"
If luck holds, you'll get an approval to talk to the RMA dept. for a product swap, and need to provide proof of purchase, etc., and will be shipped a compatible unit shortly after you send yours in.
Good luck!
Newegg advertised the switch as 9k.Don't worry about the revision details -- the tech support and RMA will know which revisions support it, and if they agree to a swap, give you one of them.
I'm talking to some dumb-ass level 1 tech as I type and he has no idea what I'm talking about. I might have to call back and try again because I'm on hold now. I can't waste my whole day on the phone with these idiots. argh.
Their response e-mail said to call in to tech. I think the reason dlink does that is because they only issue RMAs over the phone.email tech support is generally a better idea. Frees up the phone line, etc., and they also have a better chance to get things right, and when they don't, you have an e-paper trail.
Odds are that this will go back and forth a few times, and if you have to wait in the phone queue every time... I'd just give up and buy another brand instead.
