- Mar 30, 2005
Alright everyone. Our June goal is taking just a couple extra days to pass up Ukraine in POEM. So I figured that we could have a slightly less structured effort this month. Hopefully this will give folks a little bit of a break, allow them to maybe focus on some personal goals or projects less crunched and allow the team to finish its POEM goal and maybe a bit more.
Having said that I do have a couple recommendations for projects. Obviously these are just suggestions. For anyone looking to get their feet wet in a non-BOINC project Muon1 is a project where we can probably make some big progress. I'll try and find the instructions and post them below soon.
If you are looking for a BOINC project and have a CPU with 4+ threads then you might want to give Aqua a look. Its our lowest ranking in the Vault for BOINC projects. The project scores very well but IIRC only has multithreaded WUs available so a quad-core or better is a must. Otherwise another BOINC project we could make excellent strides in is SZTAKI Desktop Grid.
As always, if you have any questions feel free to ask and I will try to help. Happy crunching!
EDIT: Muon1 setup: Just download the zip file from the hompage, extract it and then put a user.txt file in the same folder as the app. The user.txt file only needs a single line for your username. Your username should be in the format [H]username. As you can probably guess using the [H] will contribute your points to the Horde and then your username is well, you username.
Then I just started the muon1_background.exe and it seems to be running. Eric correct me if im wrong here.
