Judge this setup for my next build.
Visable-assassin
I <3 Hybrids
OK ill be swapping my NF7-S ZXP 2500@2.6ghz
to a ABIT K8T800 PRO and a A64 3200+ regulare ,mobile DTR or mobile 62w.
I hear the DTR's OC like fuckin crazy is this true? or should I spring for the 62w mobile?
I know the 3000+ is a good deal...but I want that full 1mb of cache !
SO lemme know...also if someone can give a link to a good dealer that will give guaranteed GOOD OCing stepping on the 64...please post a link ! ill be doing this change here in about the next two weeks or so.
Oh and of course this will be paired with my 1gb XMS 4000 PRO :)
also what about the 3400+ DTR? or should I just stick to the 3200? help me out please since Im a newbie to the A64 arena :p
ok im new at this too but I think if you want to overclock a s754 cpu you need to get a board that has locked agp like, ASUS K8V DELUXE K8T800 S754 mobo.I would also stick with the 3200+
a read of the article on overclocking AMD 64 on hardocp.com might be a good read too if you never.
I was initially going to get a s754 64bit cpu but I really got to thinking that its not worth it and am going with a s939.
If any of this is useless or wrong, sorry :D
I would go 939 but right now ive got many other things I gotta pay for and 754 is looking very nice.
Im pretty much set on the mobo its just the CPU that im questioning right now
which one should I go for? 3200+ mobile or DTR? which will let me OC higher? Im looking for around 2.4ghz or higher.
The most performance that extra 512k of cache will get you is in your 40 yard dash time, as your wallet will be significantly lighter.
Well im saving for a new mobo and CPU...so right now its a toss up between the 754 3200+ ABIT combo
or im lookin gat a ABIT AV8 with a 939 3500+ kinda didnt wanna shell out htis much just yet...but looks like I may have to LOL :)
but the 939 is really lookin good to me...since the FX-53 may drop in price later down the road :p
If you are going to shell out the cash, might as well go for the 939 then. There is little performance difference with the added cache of the 3200+. I myself was going to wait for the 939 stuff to drop in price, but I don't think I can hold out that long, and will probably go with a 754 3000+, simply because I can make a complete system for less than a grand, whereas a 939 will be well over.
Ive actually looked over my finances and it looks like the av8 or av8-third eye paired with a FX-53...fuck it if your gonna do it...do it right :p
Only question I have is this. The FX-53 is fully unlocked correct? so I can up the multi with no problem? Unlike the regular 64s that you can only go down
K8V Deluxe has bus-locking?
I thought NO K8T800 boards had bus-locking. *lifts an eyebrow*
Try for an nForce3 250/250Gb board, or maybe on of those new K8T800 Pro boards. I don't really follow the VIA side of the AMD market.
The KV8 PRO has bus locking, Hardocp did a slight review on the thing.
However its socket 754...Im right now pretty much hard up for a 939 FX-53...I would wait for a NF3 250GB but Im an ABIT whore and they dont have one...so Ill wait till they do but for now its gonna be an ABIT AV8 for the time being...till ABIT gets a badass 250gb mobo :)
