JP[0] by JaPeMo (Acrylic Pc Case)
JaPeMo
Sponsors
My first mod started for 3 years ago, I've picked up this habit.
I am currently working in Paris (late September), but I'm already working on my new project, JP[0]
Still under study and sketching. All drawings and doodles on paper, even napkins taking cafes, which is where the best ideas are translated ...
Hardware
Motherboard: Asus Rampage IV Black Edition
Micro: Intel i7-3930K
RAM: 16GB Team Xtreem DDR3 PC3-20800 2600MHz (10-12-12-31) Quad Channel kit 4x4GB
GPU (VGA): EVGA GTX 670 FTW 2Gb SLI
Case: Full personal construction in acrylic
Hot Swap: Icy Dock MB973SP-2B
Power Supply: Seasonic X1250W (SS-1250XM)
Sound Card: Asus Xonar Essence STX
Active monitors: KRK Rokit 5 G2 (x2)
Liquid and Air cooling
Pumps: Swiftech MPC-355 (x2)
Top: Aquacomputer aquacover dual DDC
Reservoir: EK Multioption RES X2-250 Advanced
Block PB & CPU: EK-FB ASUS R4BE Monoblock - Acetal+Nickel
Block GPU: EK-FC680 GTX+ - Acetal (x2)
+ EK-FC Bridge SINGLE CSQ
Tube: Acrylico 16/12 Clear
Liquido: Mayhems X1 - Oil Black 1ltr liquid cooling
Fittings, adapters and accesories:
EK Water Blocks
EEK-HDC Fitting 16mm G1/4 - Black (x22)
EK-PSC Adapter 90? G1/4 Black (x12)
Koolance
Fitting Coupling Adapter, *Black* Male-Female, 20mm (x4)
Fitting Coupling Adapter, *Black* Male-Male (x4)
Fitting Coupling Adapter, Swiveling Male-Male (x1)
Check Valve (x1)
Bitspower
Bitspower Flow Sensor Matt Black (x1)
G1/4 Matt Black CaseTop Water-Fill SET (x7)
G1/4 Matt Black IG1/4 Extender (x4)
G1/4 Matt Black Mini Dual G1/4 Extender (x10)
Bitspower G1/4 Matt Black IG1/4 Extender 15mm (x1)
Bitspower G1/4 Matt Black IG1/4 Extender 25mm BP-MBWP-C62 (x1)
Matt Black Mini Valve With Black Handle (x3)
Others
Filter(x1)
Te (x1)
Controller:
Aquaero 5 Pro w/ water block + Flow sensor "high flow" G1/4 for aquaero + RGB Module
PowerAdjust2 USB Ultra (x2)
Temperature sensors:
Ambient (x1)
Inside case (x2)
Radiator air out (x1)
In-line in/out radiators (x4)
Radiators: Alphacool NexXxoS UT60 Full Copper 360mm (x2)
Fans:
Noiseblocker NB-BlackSilent Pro 120mm PL-2 1400r.p.m. (x8)
Noiseblocker NB-BlackSilent Pro 80mm P-1 1500r.p.m. (x5)
Others: Recycled
Lighting
5050 RGB & UV LED Strips
Documents & Galery
Acces to documents and galery about worklog
Link to Google Drive
Hi!!!
I like 2 models SAS/SATA Backplanes. Raidsonic IB-543SSK (ICY BOX) by leds, grill and full black body. But I chosen the ICY DOCK MB973SP-2B by USBs (so I avoid having to put one and cut case) and secondly because I do not need key to open. The pc will be home and will be use by me.
Other models:
- StarTech HSB3SATSASBA
- Kingwin KF-0331-BK
- iStartUSA BPN-DE230SS-BLACK
- ********** 6203SS
Specifications of ICY DOCK MB973SP-2B
ICY DOCK FlexCage MB973SP-2B Tray-less 3 x 3.5" HDD in 2 x 5.25" Bay SATA Cage - Front USB 3.0 Hub
Model Number : MB973SP-2B
Color : Black
Drive Fit : 3.5“ SATA 1.5 / 3 / 6 Gbit/s hard drive x 3
Drive Bay : 5.25" half height device bay x 2
Host Interface : 7 pin SATA port x 3
Power Input : 4 pin power port x 2 or 15 pin power port x 2 (w/ included 4 to 15 pin adapter cables)
Transfer Rate : Up to 6Gb/sec. (depending on hard drive speed)
Insert & Extract connection via : Direct SATA hard drive connection
Front Panel Contents : LED power button (Indicator) x 3 USB 3.0 Hub (2 Ports) Adjustable fan speed control (High/Low/Auto)
Structure : Aluminum body w/ partial plastic
Drive Cooling : Removable rear outtake fan w/ aluminum heat dispersion
Cooling Fan Type : 80mm ball bearing fan with 2 or 3 pin connector
Power Indicator : Blue LED
HDD Access Indicator : Flashing blue LED
Dimension (L x W x H) : 8.27” x 5.75” x 3.35”
Weight : 1.99 lbs
Photos
Good night. Finally finished shape the box.
Everything you see in the pictures is methacrylate, any components or screws. It has taken time to design without resorting to metal profiles for joint panel.
The holes you see inside is because it is smoked gray acrylic. The lines you see on grills are for out grills and clean Decimflex mesh incorporated.
Top & low
Front & back
Sides
Isometrics
Regards!!!
Hi
I come with a great news....
Yes Sires, Noiseblocker up to this travel, Thanks!!!
Regards!!!
More udates!!!
First package..
Icy Dock MB973SP-2B
The specifitacion are above. So, go to comments...
Comment that I was pleasantly surprised its weight, it is very very very light due to its aluminum body totally.
The quality and finish of all I liked it. Worth paying what it's worth.
Regards
Hi
Here (Google Drive) you have the foreground of the box. Count of materials and parts separately. Excludes RL, it's just the box with screws.
And finally, the renders. I'm not professional and they are my first render ever. So do not criticize me a lot. If you see white spots, called "fireflies", is a problem and render noise from Indigo, is not it the coated methacrylate.
As you see in the picture below, all grids (including those above) will have filters Decimfilter stuck inside and will be able to get clean.
Below you will see out that I have adapted the system used Lianli in some of their boxes, leaving the PCIs cards directly aligned with the wall of the box. This is an exterior view and fixing system of PCIs. will be able to get clean.
Pump and drain system
The tank with the trim. The deposit is transparent but has been inadvertently icing. FrozenQ also has deposits and are very handsome. It is a possibility that I wont. Sand the tank and tube to give a glazed appearance.
Inside front window
The latest images are noticed more poor quality (no more than 15 minutes pulling the render), but it is very late and go to sleep.
Regards !!!
Good news, I have new and very good sponsor....
A lot of thanks to this group, quality and good persons!!!!
You are in Paris why don't you talk to Parvum Systems about your case design? They will take your designs and cut the panels out the way you want them.
i talked a month ago, at start my project. But they said me that have a lot of projects and don't have time to done....
Regards
Hi!!!
Updates from...
Thanks to
Rads Supports from XSPC
10 adapters male-male
3 valves
7 fillports
Adapters
Filling funnel
Tube border grinding
New flow sensor/indicator. With rear 3 pin connector 3 pines. For Aquaero/Aquasuite you need set to 86 imp/l. Confirmed by Bitspower shopservice.
Splitters 5 fans / 3 pins...
I'm very surprised from great quality of Bitspower accesories...
Regards!!!
