Joystick for space combat sims.
piXel
Hi peeps, I was playing a lot of Xwing alliance and Xwing vs tie; so I bought a Thrustmaster Hotas X... but I hate it because of the deadzone being so massive and it makes dog fights annoying.
I just need something with some good accuracy. I read the Thrustmaster T1600 has a much better deadzone and its cheaper than the Hotas X but lacks a throttle. I was thinking about the Saitek x52 i can spend 100 pounds on a joystick realistically. I want to get something ordered tonight, you lot tend to always help me make the right purchasing decisions.
May want to check out CH Combat stick but it doesn't come with a throttle unless you buy it separately.
Not ordered anything yet, I was thinking, wouldn't I just be able to use a T1600m in combo with my hotas X throttle?
That tbh sounds like the most reasonable way to do it, so many people rate the T1600m for accuracy and its cheap.
