- Aug 3, 2004
http://www.hardforum.com/showthread.php?p=1032490884#post1032490884
[May 12th 2008]
okay, forget everything past this, i should start a new thread, but new project idea coming.. revolves around the same mascot i was going to do on this old project
So far all i can think of is
All white case, nice glossy white outside....
since i got the DFI x38 TR2 mobo, which has organge, i want to cut out the design above, use an orange frosted plexy glass behind it, and surround it with light so it "glows" from the case, why i think white would look good...
inside of the case not sure yet... if white or another color....
i want to get the case anodized orange but it may be more headaches to try and find someone to do it then it is worth.
[May 12th 2008]
