- Jul 17, 2006
https://jonsbousa.com/
A lot of us have been waiting for this for quite a while.. the site is up now.
It's about the coolers, not the cases.I dunno, the only ITX chassis they list comes in at 22.75 liters, not exactly SFF…
Thank you for contacting us and for your interest in Jonsbo products!
We do have another big order arriving mid-year and we should have the HP-400 Heatsink depending on our stock availability in the factory.
We are hoping to be fully stocked mid-year for more product models and options.
Thank you, please let me know if you have any further questions, and I will be glad to assist.
They have many other SFF chassis.. the site just opened, so I suspect they'll have more supply incoming for other various models over the next few months. I figured it was worth mentioning here.I dunno, the only ITX chassis they list comes in at 22.75 liters, not exactly SFF…
Regarding coolers and cases, if you do not want to make a compromise with your coolers then the Jonsbo U2 is 16L and fits every air cooler out there without wasting space on drive bays. And it's just deep enough to fit the Zotac 1080 Mini as well.
Zotac 1080 Mini will fit. I have the U1 Plus and took measurements. The official length of the 1080 mini is 208mm per SFF Network using digital calipers. I measured the max graphics card length in the U1 Plus at a little over 210mm.The U2 is too big for what it holds & I don't really like the minimal amount of air intake I am seeing…
I like the looks of the U1 Plus more, but it has some issues…
PSU up top, I don't like… Top-heavy chassis & thickest cable up top as well…
The bottom air intake (filtered is nice) is mainly used by the GPU, and the meager front/side intake seems inadequate…?
And mounting holes for two 80mm fans seems like it would fit where there is the single set…?
I dunno, I just want to see something like the Spartan Jr. but a bit deeper for the Zotac 180 Mini…
Unless Nvidia could see their way clear to make us some Titan Xp ITX GPUs (w/HBM2…?)
The substantial front air intake & good exhaust is what I would like to se in a compact SFF SFX-based ITX chassis…!
Edit: just sent them an email asking about the hp-400 ZONE. We're see what they say.
The HP-400 isn't so great. The fan clip seems a bit loose and performance is just ok. The IS-40 v3 performs much better for the same price. The HP-625 I have performs pretty darn well and the Jonsbo FR series fans are pretty quiet though.
Huh, haven't seen anyone who had experience with them, thanks for the input.
If you can, where would you rank the IS-40 v3 in accordance with, say, a Noctua L9i?
Their website seems to be broken.
I did find them listed on Amazon, but they look brand new and only offer one case:
https://www.amazon.com/gp/offer-listing/B06ZZXD5WB
Edit - 2 cases and tons of fans.
Would really like to find an RM3 Red at a reasonable price...
Yup, they are done with Jonsbo. The US distributor claimed that Jonsbo was being untruthful with them and screwing them over on business dealings. (as I heard over on SFF Network Forums)
