Joining SFF for true!
incomudro
Need to know will a 7800GTX fit in a Shuttle SN25P w/ Stock cooler? Also This is not to much strain for the PSU? w/ A dualcore 4400+ as well? Also does the SN25P sopport Dualcore AMD's w/o updating BIOS or will I have to update BIOS? Thanks!
Yes the 7800GTX fits. See machine in sig. The power supply does not have the 6 pin power connector, so you will need an adapter to still use a DVD Burner or only use 1 connector for the 7800GTX which also works.
If you are buying a new SN25P it will ship with the Y BIOS which has all the support you need.
