I haven't really seen anything attempting to read GPOs and translate them into some sort of Linux configuration. Usually you'll use a separate configuration management system or approach like Puppet, SaltStack, The Foreman/Katello, Spacewalk, or Ansible (certainly forgetting a few.)So, this thread actually brings up something I've been curious about. If I were to have a mixed environment of Windows and Linux workstations, what is the best way to implement group policies? Now, I'm certain Linux calls them something other than this, but at the server level what would be the best way to deploy a domain controller that can issue group policies to Windows clients, and then the equivalent to Linux clients? I've honestly never administered a Linux DC before, and my only experience in that area is with Windows Server based DCs.
My team uses linux with AD auth and fs permissions on the file servers ( as well as many other backend places ). Have for over 15 years, and have never had cause to regret it ( although we have had cause to regret using quickbooks...but then I imagine most administrators feel the same ).Is there any real advantage of doing this? All you really get is login credentials correct?
