SO it is summer and I am working 50 hours a weeks, so I have figured out I will have enough money for new computer I want. The mod will be based off the lacrosse team I play for SJU lax. I go to St. Johns University in MN. So ya I can not say when I will start but I am doing some sketching and maybe a few photoshops of what it will be.
I plan on having it be a desktop computer so small, I am thinking like 120mm max tall. I will be using lacrosse balls that I have cut in half for case feet. I am still debating metal or plexi construction. If metal I have two options:
1. Brushed metal with a red candy over it.
2. Solid red paint (maybe a flake)
If plexi I would some how paint the inside of the plexi to give it a glossy finish.
I want to have a lacrosse shaft cut in half and going down the middle of the front of the case horizontally, and if possible have the very center section be a pull out handle, so that when put away it would look like just part of the shaft, but then you push it and it comes out for a handle (not sure how to do it yet, let me know if you have any ideas).
On the top center I will have a circular window with our "logo?" in it below is what the etch would be.
Also some where etched on the case would be our slogan Johnnie Red you know, I will have a picture so you understand more later.
I want to try and paint the johnnie rat on the back, and also have the SJU logo some where on the case.
All while keeping it clean, and of course cause well it is like my signature now, I will have either the St. Johns cross or the trinity sigh some where on the case.
Well on to the parts.
Here is what I am planning on putting in this thing:
CPU: AMD Athlon 64 X2 4400+ Toledo 2000MHz HT 2 x 1MB L2 Cache http://www.newegg.com/Product/Product.asp?item=N82E16819103546
Mobo: ASUS A8N-VM CSM/NBP Micro ATX
http://www.newegg.com/Product/Product.asp?Item=N82E16813131010
Ram: OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM Unbuffered DDR 400
http://www.newegg.com/Product/Product.asp?item=N82E16820227084
PSU: Tagan TG-530-U15
http://www.newegg.com/Product/Product.asp?item=N82E16817101008
Sound card: Creative Sound Blaster X-Fi XtremeMusic (with remote but no front panel connector)
http://www.newegg.com/Product/Product.asp?item=N82E16829102188
Video card: eVGA Geforce 7900GT CO
http://www.newegg.com/Product/Product.asp?Item=N82E16814130281
Tuner Card: POWERCOLOR T55E-P03
http://www.newegg.com/Product/Product.asp?item=N82E16815117802
Hdd:Western Digital Raptor WD740ADFD 74GB 10,000 RPM
http://www.newegg.com/Product/Product.asp?item=N82E16822136033
Western Digital Caviar SE16 WD5000KS 500GB 7200 RPM
http://www.newegg.com/Product/Product.asp?item=N82E16822136014
DVD burner: Pioneer DVR-K06
http://www.newegg.com/Product/Product.asp?item=N82E16827129003
Cooling (tenitive):
Zalman 7000B-Cu
Zalman VF-900Cu
Cooler master Crossflow fan (intake)
Some other fans for exhaust not sure.
So thats it for now please C&C are more then welcome.
Thank you
Cooling (tenitive):
Zalman 7000B-Cu
Zalman VF-900Cu
Thank you
